$100 Amp Contest
You have to be able to purchase the amp for $100 or less, so the second that auction goes over that price, you lose. Until the auction ends, it doesn't count.
Alright alright--http://cgi.ebay.com/USED-Rockford-Fosgate-2ch-car-amp-600-w-amplifier_W0QQitemZ9704545952QQcategoryZ39737QQrdZ1QQcmdZViewItem
100 buy it now-600 wrms.
And you know this is a little underrated, and that Profile is a little overrated.
So I win?
Yep, as of now 600 wrms underrated is the leader, Bartak1 is currently the winner.
Hell, I guess I'll enter in my own contest with the amp I have, although it's very overrated and I'm very biased:
UL1700
Full Mosfet Class AB Circuitry
Green Power Coated Heat Sink
Regulated Power Supply
2 Ohm Stereo Stable
4 Ohm Mono Stable
Gold Plated RCA & Power Connections
Thermal & Short Protection Circuit
Variable High & Low Pass Filters
Frequency Response 20 Hz – 20 kHz
Switchable on/off Bass Boost
High & Low Level Inputs
4 Gauge Power Inputs
1 x 1200W RMS @ 1 Ohm
THD: 0.05%
S/N Ratio: 90 dB
http://cgi.ebay.com/1200-Watt-Power-Amplifier-Amp-Ultra-Linear-UL1700-NR_W0QQitemZ9701623534QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Apparently you're not concerned with the quality of the sound??
What is this "quality" you speak of? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif This is a cheap pos amp contest, not a zapco convention.
Ok, sorry I missed the POS description in your post //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
http://www.caraudio.com/forum/showthread.php?t=151486
Well I thought it was assumed that if you're paying less than $100 for an amp anyways, you're not even close to being an audiophile. Serious question, (assuming you are on the side of the debate that says amps effect sound quality) are there any amps that sound really good for under $100 anyways?
Absolutely man!! You gotta know how to shop //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Well, in all honesty you might have to stretch your budged by $50 or so.....maybe.
An amp that reproduces the signal faithfully, accurately and without distortion is going to sound clean and "good." Some do it better than others.
Awesome, although I'm not shopping for a new amp right now, it's good to know. Any more entries in the contest thus far?
Used old scool Orion is close to audiophile.Blows the new stuff away by a LONG shot.I took a RF Punch 801s(800 watts) and replaced it with a 225 HCCA (50 watt)and it was night and day difference on volume and bass(3 10w6 JL's)
spitfirees20
i have the re boner
spitfirees20
Rhode Island
spitfirees20
AJ (ACE)
    Jun 24, 2026
AJ (ACE)
    Jun 24, 2026
