XxXSnake23XxX
this is listed on one of my forum sites that i go to
Alpine V12 MRV-T707 Amp. Only been used for a week and it is in NEAR MINT condition (8/10 just surface scratches from the seat rails). There are no problems with this amp. Also comes with extras fuses and manuals etc.
Here are the specs:
225W x 2 (4 Ohm Stereo) 600 x 1 (Bridged 4 Ohm) FEATURES RMS Continuous Power (Watt) (at 12.0V 20-20kHz): 4 Ohm Stereo (0.08% THD) 70W x 2; 2 Ohm Stereo (0.3% THD) 120W x 2; Bridged 4 Ohm (0.3% THD) 240W x 1 S/N Ratio 100dBA Frequency Response (+0, -1dB) 10-50kHz 12dB HP/LP Crossover (50-200Hz) Speaker Level Input Bass EQ Circuit Low Impedance Drive Capability (1.3 Ohm) Subsonic Filter (15/30Hz) GENERAL 2/1 Channel Operation Bass Engine Ready Extra Large Gold Plated Terminals with Wire Insert Capability Top Panel LED 4 Volt Input Capability Continuously Adjustable Crossovers DC Straight, STAR Topology & Duo-Beta Circuitry DC-DC/PWM MOSFET Power Supply.
http://www.carreview.com/cat/car-aud...9_1806crx.aspx
http://www.alpine-usa.com/US-en/prod...odel=SWR-1042D
Alpine 10” subwoofer SWR-1042D
Brand new still in original box and packaging
only opened to snap a few photos
Here are the specs:
- Handles up to 1500W peak power (500W RMS)
- KEVLAR-reinforced pulp cone, oversized parabolic dustcap; HAMR surround and concealed mount gasket (KEVLAR is a registered trademark of DuPont)
- High-strength brass voice-coil bobbin; 50mm voice-coil diameter
- Dual progressive oversized Nomex spiders with integrated tinsel leads for added stability
- Dual stacked magnets
- Custom cast aluminum frame with integrated heat transfer plate; radial - -- vented VC heat sink and airflow management system
http://images.craigslist.org/0101040...1100b1c4 .jpg
http://images.craigslist.org/0101020...3a006b18 .jpg
http://images.craigslist.org/0101020...30007910 .jpg
this is in CND!
worth it in your guys opinion?
Here are the specs:
Here are the specs:
this is in CND!
