10" Sub Needed
the tdx was kind of a piece, and what i have heard is the d9 is the same sub. anyway, i think the mounting depth of the d9 is too much for his application anyway. the diamond d3 is still underpowered with the amp you have. i have had really good luck with the treo tsi. it is their entry level sub. i had two tsi 10"s in my truck temporarly, and it sounded better and louder than my ssi's, simply because i was overpowering them and underpowering my ssi's. for $100 a sub, you simply cant go wrong. i think it is an *** kickin sub performance and cost wise.
With your wattage i would recommend a Kicker Comp or if you think you can get away with the wattage then a Comp VR. Really cheap and doesnt need alot of wattage to get loud.
comp vrs ****, the diamond d9 is not a TDX, it uses TDX technology. if you want a good 10 and nothing that takes outrageous power i recommend a 10W3 from JL. i have a buddy with a single 10W3 and like 300 wrms. sounds better than the two 12" P3s i used to have. granted punch P3s **** but for one ten to sound better and hit almost as hard. you cant beat it
comp vr are nice
not when put up against a tsi.
then coot, the head tech over at diamond, told me wrong. according to him it was nothing more than a cosmetic makeover. the w3 is a very overrated woofer. with little power i would still take the tsi over the w3v2 anyday.
I don't know who told you guys the TDX was a piece but my D9 gets louder and sounds better than my 12" IDMAX.... it's all opinion based though!!
That would be a good dispute. I have heard both and I have to say its hard to say which one is better. I would side with the idmax on sq a tad more. But the tdx d9 was just as loud and very close on sq.
i would still take a w6v2 over a tdx anyday. i ahve had 4 or 5 tdxs
Green1340
Green1340
Texas
XtrmAudioCncpts
Mike Mccabe
