1 Tahoe + 2 Solo X's + 2 Mojo Amps + 2 Kinetik 2400's = My attempt at Meade post =)
Don't you got to go find some more "odd" pictures to post onto some avatars, sigs, and profiles?//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif I have talked to some of the mods for your info. I think the moron here is you my friend.
That is all.
Keep it to pm's bro....
also, to answer yoru question....juice em up man....as long as ya know what ya doin....they'll take it:yumyum: //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
What happens when a Mojo decides to throw some DC current at your woofer:eyebrow:
Further confirmation that these amps have to come out. He pulled up about an hour ago and this is what we found.
oh....in case you are wondering where the rest of the coil is.....YEAH....it's in the f'in gap.....
boy that was fun....NOT REALLY //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
just curious? how do you know the amps dc'ing is what caused that?
Voltage is fine...
Imp was fine...
Everything is fine.
Maybe it's not 100% DC, but when I replace the cone and put both subs on the "good" amp...I get bass. I put it back on the "bad" amp....nasty things happen. I put a different amp on that woofer....I get bass. So....maybe it's not just DC'ing....but it's definately bad. The fuse before the amps exploded.
Put a meter on the outputs and I get next to no AC voltage output.....turn it to DC and I get way more than I wanted to see.
After getting all the info together and calling a couple people to ask a few questions....this is what we came up with.
Getting the rest of the coil out of the gap was a biatch.
btw...nice sig. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Voltage is fine...Imp was fine...
Everything is fine.
eww..
dd's are the same way...lame
eww..
and if ya have any other suggestions as to why you think this happened...I'm open. I've come to the conclusion after talking with some people...other Mojo users included...that the amp just took a crap.//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
everything can blow up just depends on luck and user. their is no amp out their that is impossible to blow same with subs. so since the amp blew i guess only one amp is gonna be for sale for a while since you said in another post its not the first time you blow a 4kw and last time it took around 6 weeks to get it repaired.
btw make sure to post pictures of the new setup. 4 subs and 4 amps should hit at least 3 dbs louder. at the very least
Yes sergio....anything can blow
Yes sergio....some things do it more often, just look at earthquake
Yes sergio....only 1 is for sale
No sergio......I had nothing to do with the first blown amp,before my install
And yes sergio....the new install will most definately wang....just as this one has for two 12's and the amps at 2 ohm nominal.
thunder9500
Team Kicker
thunder9500
South Carolina
TypeRBass
