1 Ohm or 2 Ohm load? Confused.
  • 2
Tim21Va
I've been trying to help a friend hook up some DVC 2-Ohm CVX's to a mono amp for the past 2 weeks, but it seems that old amp isnt working(one pictured MTX 1500..old Jackhammer amp) so I am going to use my old amp, T-1500bdcp Rockford Power that used to be hooked up to the subs.
Here is my problem: I don't understand how to hook up these subs so it see's a 1 ohm load. Each sub is 750 RMS each, and the amp at 1 ohm load is 1500 Watts so it would then be 750 watts to each speaker so that would match. Some forums say it can't be done 1 ohm and must be 2 ohm, while others say it can....? I believe they were originally hooked up to a 1 ohm load when I had them in my car.
I will include 2 images. 1 for how we have each individual speaker wired voice coil wise so it would see a 1 ohm load per the CVX instruction manual. 2 for how we have the wires going to the amp. The amp pictured and one I will be bringing this weekend both have an internal parallel connection for both sets of speaker terminals. Which set of terminals should I use? Or does it matter?
Any help on this matter is GREATLY appreciated. I have been reading so many posts and I still feel confused.
Edit: As I understand it. If I wire a DVC 2-ohm sub Parallel it will halve the impedance of each individual coil so I could do 1ohm. If series on same sub then it would double the impedance if each individual coil to 4 ohm?
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
It also lowers the amps efficiency and raises the current draw.
355
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
223
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
889
Tim21Va
Tim21Va
Virginia, USA
Tim21Va
DEW123
    May 7, 2024
DEW123
    May 7, 2024
