1.4^ft, (2) 4" ports, (2) - SA-8s, yes..another one
  • 4
30Hertz
Well I get bored easily, and I enjoy building enclosures so heres another one I'm building for myself. I went a little overboard on the ports but I like em big.
The net internal volume after sub and port displacements is 1.4^ ft. The overall design is large due to me not wanting to have the ports sticking out so I'm making an internal wall to get the desired volume.
Ports are 4" Sewer Pipe, since I used two of them, the length was pretty long, 41.5" to be exact for 33hz tuning.
Modeled out in BBP6 I shouldn't need a SS filter due to the SA-8's not reaching max excursion till about 16hz but we'll see.
Using 3/4" Birch Plywood, first time using the stuff and ****, I think the weight difference alone vs MDF is worth its weight on gold.
On to some photo's, should be finished up tomorrow assuming it doesn't get to cold. Unfortunately I didn't really take a ton of photo's of the wood being cut into pieces, but heres some I've taken thus far.
yah, its long
cutting the holes for the internal side panel for the ports to go through the wall.
photo of the port exit on the physical side of the enclosure. I 45'd the outer portion, looking snazzy
inside of the port exit on the side,,I recessed it for the port to sit into the wood before the 45 on the outside.
test fit
I'll do more tomorrow, the front of back of the enclosure is glued up and setting in the garage drying.
Tomorrow's agenda,
take out current enclosure and take out the SA-8s
cut baffle and recess baffle
glue sides and baffle in place, then glue top panels
More work done today, assuming the caulk is dry by tomorrow, it'll be going in.
The majority of the day I was fiddle-fawking trying to get the ports secured. Started off with caulk but with the temperature so low..it wasnt setting, switch to PVC glue...then calked around it and set it by the heater to set up, it aint pretty, but it should work.
Made a booboo on the first baffle by cutting the holes to big, rather than doing a patch job I had some spare MDF laying around so I used that, not exactly what i had planned but **** happends.
Cut the top birch baffle perfect
Top and sides were 45'd, wanted to try something other than a round-over...small 45 on the cutouts too
Rather than how I usually wire..decided to try it this way..got the enclosure pre-wired for easy drop in tomorrow.
thats it, tomorrow I'll finish taking out the enclosure and installing this one..tuning, then videos
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
30Hertz
30Hertz
Central Cali
30Hertz
    May 31, 2024
    May 24, 2024
