1/0 Welding Wire Vs 1/0 Alumnium Wire
Some say welding cable is not as good as CCA wire for car audio
and some people get their penis stuck in the jacuzzi do you want to do the same? copper is a better conductor ask any electrician the aluminum is just lots cheaper. I do want to see how much better tinned copper holds up to corrosion. I have heard it does but want to see some good proof in a side by side.
copper is a better conductor ask any electrician the aluminum is just lots cheaper. QUOTE]
Copper has a higher ampacity rating. When using aluminum conductors, the standard is to go to the next recommended size for the application. That is per the NEC(National Electrical Code).
i bought the 4 guage wire from home depot just because i wanted to test a amp... each strand was real thick and there were not alot of strands.. is that welding wire?
no, thats probably wiring for a house. super stiff?
AFAIK home depot/lowes doesnt have welding cable
Burp09
Burp09
meridian, ms
xtremebassjunky
