mendon mafia
`94 caprice, 15" Fi BTL
ok so ive recently been wondering why my voltage in the rear is about .2 less than up front and i think it may be due to the fact that my ground wire from front to rear is 2 shorter pieces of 1/0 soldered together using a splicing tube.
my question is should I unsolder the wire and solder on ring terminals and them bolt both to a common position on the chassis or should i just leave it as is? which will yield higher conductivity?
I plan to add another continuous run for + and - but i dont have enough wire for 2 new continuous wires for the ground so i can leave it as is or essentially use ring terminals to create the connection rather then the splice tube.
