SOLD 1/0 Big 3 Upgrade Kits Starting at $25!!!
scottiej
It's a shame I've got all this perfectly cut and terminated wire laying around and nobody is using it... here's how this works.
Pop your hood, and guestimate the lengths of the follow 3 cables:
1. Alt output to battery positive.
2. Battery negative to chassis.
3. Chassis to engine block.
An easy way to get a close measurement is to take a small piece of string or wire and lay it where the wire will go. Cut it with a pair of scissors to the length you need it to be. Do this once for each of the three cables above, and measure their length in inches.
Once you know the lengths you need, refer to the list at the bottom of this post and find the closest cable that will work for your installation. If you are in doubt, go with the next size up cable because you can always route the cable another way and tie it up out of the way. Some cars can be done for $25 or less plus a little bit of your time... some cars will take more.
Here are some pics...
Here is the list of available pieces...
Qty - Size (in.) - Color - Terminated - Price Ea.
28 - 7.25 - Yellow - 2 x 3/8" Ring with Red Jacket - $3.00
4 - 11 - Yellow - 2 x 3/8" Ring with Red Jacket - $5.00
11 - 7.25 - Silver - 2 x 3/8" Ring with Red Jacket - $3.00
3 - 24.5 - Silver - 2 x 3/8" Ring with Red Jacket - $6.00
13 - 24.5 - Silver - 2 x 3/8" Ring with Black Jacket - $6.00
3 - 28 - Silver - 2 x 3/8" Ring with Black Jacket - $7.00
18 - 34 - Silver - 2 x 3/8" Ring with Black Jacket - $9.00
1 - 38 - Silver - 2 x 3/8" Ring with Black Jacket - $9.00
1 - 40 - Silver - 2 x 3/8" Ring with Black Jacket - $10.00
5 - 42 - Silver - 2 x 3/8" Ring with Black Jacket - $10.50
8 - 44 - Silver - 2 x 3/8" Ring with Black Jacket - $11.00
8 - 54 - Silver - 2 x 3/8" Ring with Black Jacket - $13.50
3 - 64 - Silver - 2 x 3/8" Ring with Black Jacket - $16.00
5 - 73 - Silver - 2 x 3/8" Ring with Black Jacket - $18.25
27 - 41 - Silver - 1 x 3/8" Ring with Black Jacket - $10.25
21 - 50 - Silver - 1 x 3/8" Ring with Black Jacket - $12.50
1 - 21.5 - Red - 2 x 3/8" Ring with Red Jacket - $6.00
5 - 24.5 - Red - 2 x 3/8" Ring with Red Jacket - $6.00
1 - 28 - Red - 2 x 3/8" Ring with Red Jacket - $7.00
12 - 30 - Red - 2 x 3/8" Ring with Red Jacket - $7.00
3 - 32 - Red - 2 x 3/8" Ring with Red Jacket - $8.00
17 - 34 - Red - 2 x 3/8" Ring with Red Jacket - $9.00
5 - 42 - Red - 2 x 3/8" Ring with Red Jacket - $10.50
12 - 44 - Red - 2 x 3/8" Ring with Red Jacket - $11.00
3 - 48 - Red - 2 x 3/8" Ring with Red Jacket - $12.00
6 - 54 - Red - 2 x 3/8" Ring with Red Jacket - $13.50
3 - 64 - Red - 2 x 3/8" Ring with Red Jacket - $16.00
5 - 73 - Red - 2 x 3/8" Ring with Red Jacket - $18.25
4 - 38 - Red - 1 x 3/8" Ring with Red Jacket - $9.00
28 - 50 - Red - 1 x 3/8" Ring with Red Jacket - $12.50
1 - 64 - Red - N/A - $16.00
I will try to keep this list updated as frequently as possible so everyone will know what is remaining.
yes, please let us know what the status on this sale is. This is great //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
A company should start selling big 3 kits though, they'd make money off of it...
They do, the only difference is they sell it as 1/0 and ring terminals.
If your unable to do a simple upgrade like the big 3 without needing a "kit", you need to find a new hobby.
Dude, i was just saying a company could make money off making kits with enough wire and terminals for the Big 3 only....
Not that i need one, but it would help to get the right amount of wire to do it when it's all you need wire for and it would help newbies...
Well considering EVERY car is different, they would have to offer a zillion different kits. It's not that hard to do, even for noobs.
Instead of having different lengths for each car, they could have a piece long enough to cover any vehicle....
****, didn't realize this thread was still active. I've still got a few pieces remaining. Here's what I have at last count.
16 - 7.25 - Yellow - 2 x 3/8" Ring with Red Jacket - $3.00
1 - 73 - Silver - 2 x 3/8" Ring with Black Jacket - $18.25
22 - 41 - Silver - 1 x 3/8" Ring with Black Jacket - $10.25
5 - 38 - Red - 1 x 3/8" Ring with Red Jacket - $9.00
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
944
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
scottiej
scottiej
Knoxville, TN
mojo212
audiobaun
    May 19, 2024
    May 19, 2024
