SOLD 1/0 Big 3 Upgrade Kits Starting at $25!!!
scottiej
It's a shame I've got all this perfectly cut and terminated wire laying around and nobody is using it... here's how this works.
Pop your hood, and guestimate the lengths of the follow 3 cables:
1. Alt output to battery positive.
2. Battery negative to chassis.
3. Chassis to engine block.
An easy way to get a close measurement is to take a small piece of string or wire and lay it where the wire will go. Cut it with a pair of scissors to the length you need it to be. Do this once for each of the three cables above, and measure their length in inches.
Once you know the lengths you need, refer to the list at the bottom of this post and find the closest cable that will work for your installation. If you are in doubt, go with the next size up cable because you can always route the cable another way and tie it up out of the way. Some cars can be done for $25 or less plus a little bit of your time... some cars will take more.
Here are some pics...
Here is the list of available pieces...
Qty - Size (in.) - Color - Terminated - Price Ea.
28 - 7.25 - Yellow - 2 x 3/8" Ring with Red Jacket - $3.00
4 - 11 - Yellow - 2 x 3/8" Ring with Red Jacket - $5.00
11 - 7.25 - Silver - 2 x 3/8" Ring with Red Jacket - $3.00
3 - 24.5 - Silver - 2 x 3/8" Ring with Red Jacket - $6.00
13 - 24.5 - Silver - 2 x 3/8" Ring with Black Jacket - $6.00
3 - 28 - Silver - 2 x 3/8" Ring with Black Jacket - $7.00
18 - 34 - Silver - 2 x 3/8" Ring with Black Jacket - $9.00
1 - 38 - Silver - 2 x 3/8" Ring with Black Jacket - $9.00
1 - 40 - Silver - 2 x 3/8" Ring with Black Jacket - $10.00
5 - 42 - Silver - 2 x 3/8" Ring with Black Jacket - $10.50
8 - 44 - Silver - 2 x 3/8" Ring with Black Jacket - $11.00
8 - 54 - Silver - 2 x 3/8" Ring with Black Jacket - $13.50
3 - 64 - Silver - 2 x 3/8" Ring with Black Jacket - $16.00
5 - 73 - Silver - 2 x 3/8" Ring with Black Jacket - $18.25
27 - 41 - Silver - 1 x 3/8" Ring with Black Jacket - $10.25
21 - 50 - Silver - 1 x 3/8" Ring with Black Jacket - $12.50
1 - 21.5 - Red - 2 x 3/8" Ring with Red Jacket - $6.00
5 - 24.5 - Red - 2 x 3/8" Ring with Red Jacket - $6.00
1 - 28 - Red - 2 x 3/8" Ring with Red Jacket - $7.00
12 - 30 - Red - 2 x 3/8" Ring with Red Jacket - $7.00
3 - 32 - Red - 2 x 3/8" Ring with Red Jacket - $8.00
17 - 34 - Red - 2 x 3/8" Ring with Red Jacket - $9.00
5 - 42 - Red - 2 x 3/8" Ring with Red Jacket - $10.50
12 - 44 - Red - 2 x 3/8" Ring with Red Jacket - $11.00
3 - 48 - Red - 2 x 3/8" Ring with Red Jacket - $12.00
6 - 54 - Red - 2 x 3/8" Ring with Red Jacket - $13.50
3 - 64 - Red - 2 x 3/8" Ring with Red Jacket - $16.00
5 - 73 - Red - 2 x 3/8" Ring with Red Jacket - $18.25
4 - 38 - Red - 1 x 3/8" Ring with Red Jacket - $9.00
28 - 50 - Red - 1 x 3/8" Ring with Red Jacket - $12.50
1 - 64 - Red - N/A - $16.00
I will try to keep this list updated as frequently as possible so everyone will know what is remaining.
Are all cables #1/0? Some of your pictures look smaller, & I need some #2 & #4.
I will also need some #1/0 short jumpers for new battery setup.
Thanks, Ja-son
I,m workin with 1998 Nissan Maxima - added somewhat sound system - interested in big3 upgrade. From following battery + to alt, negative to chasis to engine block - wiring under hood. Noticed connections look nothing like most cars carry. Would upgrade work for 98 maxima . . . .if so tell me where battery + go to, if not directly to alt. . .
Basically looking for little direction . . .
good price?? lol what brand wire?? i can do tsunami wire with strand counts for 2.50 a foot terminals included... its real 1/0 not monster cable with 1/4" thick wrapping that is hard to work with and will fit in a 4 ga terminal.. i dont have precut wire either.. i can cut it to the length YOU need.. guess i need to make a thread
Dude, Was that really necessary... The OP is selling 1/0 tsunami of compotition power wire
dude .. is that really legible.. i have no clue what you just said.. and obv it is necessary because i have already sold over 100' of wire since i posted.. If there is a better deal to be had they should know about it... i guess evryone not ballin like youand can pay more and get less.. but by all means
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
984
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
scottiej
scottiej
Knoxville, TN
mojo212
