06 Impala SS Help
Mikerad89
RI
Hi all
I’m trying to replace my head unit. I don’t care about retaining onstar or even chimes. The past two harnesses I bought for my car just don’t match up to the wiring on the stock harness so I’m getting no power.
This is the harness I bought: https://www.amazon.com/gp/aw/d/B01N8...?ie=UTF8&psc=1
This is the unit: https://www.amazon.com/gp/aw/d/B01IB...f=yo_pop_mb_pd
I also bought a PAC smart harness and I’m having the same issue. Listed for my car, but the pin locations on the harnesses don’t match.
Cut and splice? Is there a harness I’m not finding?
Need some serious help
I know the diagrams for the factory harness and the one that came with the headunit. The issue is that when I wire the aftermarket harness to the headunit harness The wires don't match up correctly to the factory harness.
Plus I've heard soemthing about the ACC wire needing to be run to the fuse box to shut the radio off when the car is off? Sounds like a pain.
This harness SAYS it fits, but can anyone definitively say it does?
https://www.crutchfield.com/p_120OSLAN01/Axxess-GMOS-LAN-01-Wiring-Interface.html?tp=3486&awkw=75640665145&awat=pla&awnw=g&awcr=47641946665&awdv=c&awug=9002142
What do you mean they don’t match up?
Are there wires missing?
When the harness is plugged into the factory wires the 12v, ACC, speakers wire, etc don't match up with the correct pin location.
Mikerad89
Mikerad89
RI
Mikerad89
Mike Mccabe
