04 Bonneville trunk build
When using MDF pre drill your screw holes and u won't be splitting wood like that in your picture. //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
I actually did haha. But I think they must have not been big enough.
Either way. This box will only be around a month or so. I'm going to 2 15s as soon as possible. This was like a good practice run.
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
738
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
dudeogo
Actually a Potato
dudeogo
Springfield, Mo
CSCStang
    May 18, 2024
    May 18, 2024
