04 15xxx box dimensions
Gilliz
Habitual Tendencies
Hey,
Dave from RE recommends 4cft@34hz ported. Best I can find is moe lesters 4cft@35hz. I punched them in at the12volt, and it says 5.40213cft^3.
My trunk dimensions are 28" depth / 40" width / 19" height. (Given max width & height to be able to fit enclosure is 19 height x 40 width).
This will be my first ported box build:(. Any help with dimensions would be great.
Thanks.
you will be fine with moe lesters box.
buddy had one in 4.1 cubes @ 29hz.....low end like a *****
Could you get / help with the dimensions on that pls?
Box newb, so help would be nice loo. thx!
It'll be seeing power from Saz 1500D. Still hella loud?
yes. that is more than enough power for that sub. you can probably go with a little smaller box as well.
tell you what, give me your max dimensions you want to work with and ill come up with a box real quick. i dont normally do this because i just dont like to, but ill make an exception. im assuming you want port and sub back?
Port ans sub back yes.
MAX dims are 28" depth / 38" Width / 18" Height.
Thanks
4 cubes yes. I'm up in the air about tuning. I wan't to be between killer low end and loud pls!
Soooo, maybe 29, 30, 32 ish? Your opinion?
Thanks.
Thanks.
honestly the XXX has no problem getting low. you would be fine with any of them. lets just stick with what david recs.
Gilliz
Habitual Tendencies
Gilliz
MidWest
fbi90909
michigan born
    May 14, 2026
michigan born
    May 14, 2026
