HELP! Fiberglassed Enclosure Vibration in Spare
lippstuh
Okay, so my enclosure holds 3 subs. It fits right into the spare tire well. I made it so that you tighten the enclosure where you tighten the spare. The bottom half is all fiberglass while the top where the subs are mounted are on a mdf board. Now when the subs start hitting hard there is a vibration from the enclosure hitting the trunk.
Now is there a way to get rid of the sound? I was thinking putting a layer of foam where the enclosure touches the trunk or something. I'm such a noob. =\
foam , carpet padding , all kinds barrier material. spray it with some kind of anti mildew spray first. If your trunk ever get's wet, that's where the water will go. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i was thinking foam too.... okay here goes
take out subs out of the fiberglass enclosure, then put foam into trunk area. quickly put in the enclosure then the foam will make somewhat of a mold? is this correct? what kind of foam do you guys recommend.
sound deadening... do i just put these on where the enclosure touches? any special ones you guys suggest?
thanks for helping a noob out =D i really appreciate it
I would just get a piece or two of close cell egg crate foam , or carpet padding , throw it in the tirewell then put the enclosure in on top of it . //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
just buy some speaker box carpet. maybe just a yard of it. cut it into large patches and glue it(3m spray glue) to the bottom(outside) of your fiberglassed box. if you see wear onto the trunk floor from the fiberglass vibrating then those would be hot spots on adding capet to.
lippstuh
lippstuh
Temple City, CA
bikinpunk
