02 Acura CL-S New Build *AQ, Polk, Sundown, etc.*
That is an expensive component set.... tell us how it sounds when you get it working.
Should be up and running next week. I plan on putting up a review on the 100.4D and the Speakers once everything is up and running!
Alright well I think I've figured out part of the problem!
So here is some updated pics.
The sub wall mounted:
The amps test fitting:
Are you planning on upgrading the alternator and add extra batteries?
802
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
😩 😩 😩 😩 😩 That deff sounds like azz man. Id run another ground wire from the HU to a good solid ground location cleaned off and bolted down.Id use...
16
Echo42987
Echo42987
Antioch, IL
Echo42987
    May 24, 2024
