00 lexus gs300 full jl build
caliboyta
hey guys been a while. Picked up a newer daily driver and proceed to go under it skirt with a full blown jl system. Stay tuned
headunit: pioneer dnm-wc6600nex
front comps: jl c6-650
rear comps: jl c6-650
subs: 2 10 jl w6
box: custom bandpass, ported up the rear deck
comp amps: jl vxi 800/8 running active
sub amps: jl vxi 1000/1
2 optima batteries
big 3 upgrade
jl vxi hub
jl drc-205
Build Photo
  1. Not right now
Cost? What is your budget? From Audiobaun. Okay. Or doing this job for someone else. 1 ohm? Lower resistances. Give specific examples when you need 1 ohm resistances. Like where in the car. #18 wiring gauge at the speaker end, 2 front fills. How will this make the sounds any better? Because I've noticed sometimes too the music cannot be heard in the back of the car. This would be nice and helpful for some of us who may not know your situation. Are you sure you're a 10 year member. Is this going to work? I know this is the car audio club. But I've never heard of anyone having specific specs to work with every time. All different. This specs look like crap. For example, from reading other blogs, the red #`18 wire from the factory is connected to the ACC terminal on, on the ignition switch. The yellow is connected to the battery. By connecting the red and yellow wire at the radio side harness, you actually turn on the amps at ignition. Blue-white, remote wire connected there, also going to the amps. #18 wiring gauge too to the amps. Use the car fuse box to connect those wires. Orange, black, yellow, red, blue, blue-white. Detail wiring says your setup won't work. Uniform and linear are amplifiers. Radios or external amplifiers. And thank you for your input. California!​
caliboyta
caliboyta
newark, ca
Mitchell Fosgate III
