I recently installed a sub and amp into my sister's car, its a 2002 Chevy blazer it has a stock stereo. I installed a line output converter because there were no RCA connections and I wired the remote wire to a wire that said it was 12v on a website's wiring diagram (I can post it if needed)...
Hello, I have a 2006 Honda Civic, running a Boss R110m amp with 2 8ohm subs in series, using a PAC-SNI 35 LOC, with stock head unit. I have the amp powered getting the remote turn on wire from a fuse in the fuse box, and I will be hooking it up to the proper wire soon, but for now it powers on...
Earlier today I was driving on the road and bumping my music then the sub stopped working. The volume wasn't rally on high. The radio is working properly (Kenwood KDC-BT652U). The amp lights up red when the radio is on and will go off when the radio is off (Kenwood KAC-5001PS). But, no sound...
Hello about a week ago when I was thumpin my subs they stopped working, I had them turned them up too much. I have 2 kicker cvr's 350 watt rms, kicker zx750.1 amp, alpine CDA-9887 head unit. What I know is that the settings on the amp was way too high, my volume went up to 15 (out of 35) before...
I have 2 fi qs hooked up to a rf bd 2000. The load the amp is seeing is 2 ohms from each sub. One just stopped working. It isn't the amp / rcas because I switched speaker inputs and the other sub still worked. There's no damage to the cone, it didn't stink, and all the voice coils read as they...
So I bought a 2001 Dodge Ram that came with a nice setup. I was troubleshooting some other issues and disconnected the stereo from the truck. When I plugged it back in, nada, no workie! Its a Alpine CDA-9886. I have power all the way to the back of it. I have checked and rechecked every fuse and...
Ok, so I bought myself a new car (Nissan X-Trail). The new car had a built in navigation system, so I had to pull the audio from the rear speakers and use a step down converter. After connecting everything up, I find that the subwoofer is not working. (Everything was fine in the 95' Jetta)
I...
