aidanmobrien5
Tech Support
I have a 2014 chevy sonic that I have been in the process of installing a new headunit in. Previous to this I already had a sub wired into the car with the control wire being part of an add a fuse in my cig lighter fuse in the interior fuse box. I tried to wire the acc wire from the new headunit into the fuse box also using an add a fuse unknowing that you are not supposed to use multiple add a fuses in the same fuse box. I put the second add a fuse in the ipc slot and now I have 0 audio in the car. No stereo audio and also no chimes, seatbelt warning, turn signals etc. I have unplugged the battery for 30 minutes to try and reset the system and I have also checked all fuses associated with audio loss in the interior and most of the under the hood fuse box. After all of this I still have no audio, and also no clue what the issue is. I just need some pointers as to possible solutions because I'm not a car guy, I dont deal with cars often I just was trying to get a better sound system in.
