Krystal Kable 2 Channel 6M Twisted Pair RCA , outer ground case touch each other
my2006c6
Junior Member
I haven't installed them in yet but my, , KnuKonceptz Krystal Kable 2 channel twisted pair RCA are a tight fit at H.U. and Amp and i see the outer casing (ground) touch each other when connected. Seems this could be a issue with some amps ??? Is it ok ? As how does one know if say at the amp if the L and R use the same ground path
I wrap one tightly with Tesa tape. Just in case.
Not an issue. For example: standard stereo headphone jacks share the same ground.
my2006c6
Junior Member
my2006c6
United States
mahc
