Help with vfl 4500.1d amp
absosecur
First thanks for having me. I have a vfl 4500.1d amp and two american bass subs. The subs are wired to two terminals on the end of the box. My amp has right and left speaker outputs. How do i connect just two leads from the amp to pos and neg on sub box. This is a mono amp so i dont know if i connect speaker wires to left or right pos and neg output or like left negative and right positive output on amp. I cant find installation help on this amp online. Please help
How can I assist you with your car audio setup?
It’s a mono amplifier. There is only one channel. The two sets of speaker terminals are just there to make it easier wire multiple speakers to it. Just pick any + and - terminal and use it.
Seconded. Those external connectors are connected to each other behind the wizard's curtain, and they don;t care which ones you use, as long as you do not go below the recmmended impeadance for the amp.
If you want to share a sketch of your wiring and the amp and sub stats, we'd be happy to confirm you are "safe".
absosecur
absosecur
raymond ms
RobGMN
