Featured Advice Needed: Bose stereo upgrade 2023 Chevy Silverado 1500
KcContractor
I'm ready to upgrade the crummy bose system in my truck. Not sure if I should get a dsp unit or an amp with built-in dsp. I want simple, good, quality and a good price point/used option of a higher-end unit.
I just bought a single JL 12TW3-D4. I'm not sure if this will be enough or not as I haven't hooked it up yet, but I'm open to getting a second one or even doing 4 8's or some 10s. The sealed enclosure may not be very good on the JL I bought. Any advice is appreciated.
I'm not sure what harnesses I'll need exactly. I've seen some T harness options online.
I could use the existing component speakers in the doors, but I may as well upgrade them while I'm there. Suggestions are appreciated on everything!
Thanks!
Thanks!
### Upgrading Your Audio System
#### DSP vs. Amp with Built-in DSP
1. **DSP Unit:**
- **Pros:** Greater flexibility and tuning options. You can adjust settings for different types of speakers.
- **Cons:** Requires a separate amplifier, which can complicate your setup.
2. **Amplifier with Built-in DSP:**
- **Pros:** Simpler installation, more compact, and can be less expensive than buying both separately.
- **Cons:** May lack the advanced tuning options found in standalone DSP units.
#### Subwoofer Configuration
- **JL 12TW3-D4:** A single 12-inch subwoofer can deliver impressive bass, but it largely depends on your listening preferences and the enclosure quality.
- **Upgrading to Dual Subs:** Adding a second JL 12TW3-D4 would significantly increase the overall bass response. Alternatively, using four 8-inch subs or ten-inch subs could provide more punch but may require more power and tuning.
#### Sealed Enclosure Consideration
- If you suspect the existing sealed enclosure is suboptimal, you might consider a ported enclosure for more low-end output or ensuring that your sealed enclosure is properly sized and built to the JL specifications.
#### Choosing Component Speakers
- **Upgrade Recommendations:**
- Look for high-quality brands like Focal, JL Audio, or Infinity for your door speakers.
- Component speakers generally offer better sound quality due to separate woofers and tweeters.
#### Harnessing Options
- **T-Harness:** This is a great option for plug-and-play installation while retaining the factory radio functionality. Make sure to choose one that is compatible with your vehicle's make and model.
### Summary
- **Recommendation:** If you prefer simplicity, go for an amp with built-in DSP. If you want more control and plan to expand your system, opt for a standalone DSP.
- **Dual Subwoofers:** Consider adding another JL 12TW3-D4 for better bass response.
- **Speaker Upgrade:** Invest in quality component speakers to enhance your audio experience.
- **Harness:** A T-harness is a convenient way to connect new equipment.
Feel free to ask if you need specific product recommendations or installation tips!
The first step is extracting a useful audio signal out of the Bose system, which is easier said than done. You will need an interface to remove factory filters and provide a clean, useful signal. You also need to understand if there are noise cancellation microphones that require bypassing.
Crutchfield is your best resource for getting started, as they can get you the right components to interface with the stock Bose system then amplify your sub.
KcContractor
KcContractor
Olathe, KS
keep_hope_alive
