Help with drop in volts
Jonathan37334
Tn
Hello , have a question but first off my setup . 2 sundown ns-v6 15in subs 3k rms, 1 salt -4 sundown 4k rms watt amp, 200amp/hrs audio battery, 350 Amp alt added along with I think 195 Amp factory alt,all 0 gauge ,2 400 Amp fuses , 8cuft box 32 htz . I'm running at 16.2 volts and I have a 6volt drop when slapping very hard (10.6v). I believe I know the issue but see if anyone can confirm my suspension.
  1. Not right now
I think you should check your voltage with something else. 16.2 volts would destroy your battery(AGM) and that Salt amp would not turn on at that voltage. They protect at 15.5 volts.
Agreed...
I'd suggest adding power but user foilbiles apply... I'd power a pair of Nsv-6 15's with something like 8K+ myself
Once again expectations meet reality
The bass knob that came with amp shows voltage at 16.2 then same om both my meters but I have audio battery and 350 amp alt together going to amp and the truck battery and factory alt are together both are separated
Jonathan37334
Jonathan37334
Tn
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
