Super/Ultra Capacitor v. Second AGM Battery
zoltman1991
Questions regarding “super” caps.
I have:
-fosgate T1500
-two MRV-f300s
-big four
-AGM hood
-300a alternator in the mail coming
Right now, my two 12s are in a large box. There’s a lot in the trunk. My rear is already sitting a little low. I have the XS XP4500 sitting at the house, but this thing weighs another 77lbs or so.
Not familiar with super caps. I know “normal” caps are effectively worthless. But in this system, to avoid adding the additional weight, would a supercap do well? Resting voltage 14.1. Moderate play can drop to mid 13s. If I go heavy, it can hit low 12s.
are these funny about voltage? I saw that OP said Resting voltage 14.1. Moderate play can drop to mid 13s. I am learning this world and see some say your resting voltage is too low for certain brands/set ups.
The glowe would help keep the voltage up...but you can ask them if you have concerns...they're good about getting back to you
I have:
-fosgate T1500
-two MRV-f300s
-big four
-AGM hood
The internet is full of people who don't understand the purpose of capacitors, so capacitors get a bad rap. I assure you that capacitors are not worthless, and there is no such thing as "super capacitors", "ultra capacitors", or "normal capacitors"; there are only capacitors. If capacitors were garbage, they wouldn't be used in any circuit.
What you want is a lithium battery. Lithium has speed and capacity that is ideal for car audio. If I had tried lithium before buying my alternator, I don't know if I would have even needed the alternator.
If the 300A alternator is in the mail I would install it and see how your voltage does before making any other moves.
"Do what you were going to do". Awesome advice. Thanks.
A helpful post would say something like "the alternator is not going to help your voltage drop, because alternators do not generate electricity until they see a dip in voltage.
zoltman1991
zoltman1991
houston
metalheadjoe
