Completed Shallow 10
Looking for shallow mount 10, dual 4 or dual 2, mounting depth no more than 3.5”. Cut out no bigger than 9 1/8 or 9.125. Budget $200
Have you scutinized the Pioneer shallows?
.125 inches bigger than specs asked but ok depth wise. $129 seems compelling and their other other subs perform well
This is the specs on that TS-Z10LS4
Cut Out dimensions
9-1/8,23.18 cm
Equivalent Compliance (VAS)
23.7 Liters,0.83 Cu. Ft.
Free Air ResoNAnce (Fs)
35
Linear Excursion (Xmax)
9.5 mm,3/8
Mounting Depth
3-1/4
Port Diameter
3,7.62 cm
Port Length
7-1/2,19.05 cm
Recommended Ported Box Internal volume
17 Liters,0.60 Cu. FT.
Recommended Sealed Enclosure Volume
0.6 Cu Ft,17 Liters
Total Speaker Q (Qts)
0.52
Just not sure how this would work in .9cu.ft
Guy over on DIY has a TS-Z10LS4 for $100
Maximum enclosure is .7, I’d be at .9. RMS is 400 I would be at 300. So wonder how it would sound
Oversize is not an issue as you can fill in with a temporary dividing wall.
As for the lower power, it is also not an issue. I got an old 12" Pioneer in a 0.8 sealed and it sounds better at a lower volume than the RMS.
$100 is a good deal, snatch it up. If it does not meet your expectations, you can sell it at the same price.
Should do good...the slightly larger box should let it play a touch lower and you'd never hear the difference between 300 and 400 watts anyways
Going with 10's that are no more than 3.5" deep, you might as well go with 8" subs and port the box. You'll get more sound out of it. The 8" Kicker L7T's will pound pretty good in a ported box.
This is an SQ install. 3 way component set up front. CDT CL-69SUB CF, in front doors, Unity 7.5 in dash, Stereo Integrity M25 MKII tweeter in pods. CDT coaxials in rear doors.
Amp Stinger MT1000.5
AudioControl LC7 Pro
An 8" ported box will still sound amazing, if it's ported right. A 10" SQ sub for $200 that is 3.5" deep and a cut out at about 9-1/8" are slim pickings. JLA would be really nice, but they are pricey.
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
