Memphis mb1024 10. Inch woofers
Fast Eddy
I got two MB 10-in 10 24 Memphis they have the two and four ohm jumpers on one side to a dual voice coil so I have a pioneer GM e360x4 2 3 or 4 channel amp I try to bridge how do I wire those woofers if I can't jump them cuz there's only one set of voice call inputs on the speaker please help
The side that has 2 terminals goes to the amp. The side with the four terminals will be the resistance setting. On that side you only use the jumper on the resistance you want to use.
Each sub at 2 Ohms paralleled at the amp will give you 1 Ohm.
For 2 Ohms use one jumper from Blue to Gray and one jumper from Black to Orange.
Ty so In can wire direct from the pos to pos speaker to amp neg to neg it just don't sound rite I used the meter I have 2 ohm everywhere gonna send my amp model if u can verify were or how to wire it if poss I appreciate it Pioneer GM-E360X4 1000w max power amp
Yes.
You will have to set your subs to 4 Ohms. The red dots are where to wire the subs. The amp is marked with the polarity.
These are the x-over settings. You will do this for the other side as well.
Yes.
Yea I had the woofers on 2 ohms and I had a tied into the amp on the top four I didn't Bridget so I had it all wrong I really appreciate the help mani hope to get on it today and let you know I make out
Fast Eddy
Fast Eddy
New Jersey
Fast Eddy
