Multi speakers
07FLSTC
Hello all, need some wiring advise for some speakers. I have four JBL 3ohm speakers and two 4ohm tweeters, I am running a amp the can run either 2ch at 4 or 2 ohm, or bridged 1ch at 4ohm only. I'm trying to navigate a way to wire all these speakers, that the ohm range will be stable. Any ideas?
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the left and the other combo on the right. Make sure the 4 Ohm tweeters have the capacitors/crossovers in them.
For safety try each combo in series. If not enough juice, try each combo in parallel and keep a hand on the amp's temperature.
07FLSTC
07FLSTC
Sacramento
