CarAudio.com Exclusive
Looking to go for a cheap SQL build in the back of my Jeep. Have around $350 to play with and was looking at going for 2 ok 15s vs 1 "better" 15. Will be going on a JP8 amp so getting around 1000-1200 my voltage is usually steady at 13.8-14v
Was thinking about either going for 2 NVX VSW 15s wired in parallel to 1 ohm and can be had with a box for ~$340 at SonicElctronix. Box is 1.9 cubic feet which is right around what NVX calls for
Or a SoundStream T5 Tarantula 15 also wired to 1 ohm on the same box and can be had for around the same price give or take $10. Same box
The VSWs have 11mm of linear xmax and the Tarantulas's isn't listed but I assume is somewhere around 20 mm. Going for a good amount of SQL, leaning a bit more towards SPL. I listen to metal and rap and plan on crossing over at 100hz to blend nice with the midbass.
P.S. anyone know where to get decent 1 inch metal dome tweeters for around $40? All's I can't find is Morel and JL for $90-100.
