LTO bank vs LiFeP04 for daily system
I'm intending on converting it to 12v by cutting the one bar on the pack. No real reason to re-arrange the cells if it fits how it is.
I believe you are correct. It's been a while since I've had a beast module in hand.
It's not an uncommon thing to repurpose the 24v setups bars. Just something I haven't seen in a little while personally.
You just have to cut one bar and you get 2 seperate banks. From there you just add 2 jumpers and bam, a 96ah 12v pack with balance leads.
Yea I've seen it done just been a while
So, with this arrangement I would be running 4s12p. I'm not 100 percent sure, but I'm guessing I can use a single BMS since each batch of 12 cells will self-equalize and we just need to match the 4s.
Does anyone have any suggestions on a remote voltage/amperage display?
Matt
Matt
Yes 1 balancer will work.
The remove voltage/amperage display is using a digital shunt.
Question: if he doesn't run the lifepo4 bank under the voltage threshold, would the cycle life be a factor? Also asking for me as well lol
Obviously the published cycle life figures are under optimum lab conditions. Over voltage, or big peak current charge/discharge should further reduce expected life. Though the "life" published is generally still leaving cells at 80% of new so it's not like you throw them away after that point either.
DO consider how big the bus bars are. Is the material sufficient for the current you'll be trying to run?
It's tinned copper, about 1/8 thick from what I can tell, should be plenty. I do intend to re-build the packs and put them in HDPE ammo boxes down the line, when I do that I'll end up using some different bars.
Matt
Matt
The key is cross sectional area.
Yea, the link says "300a" buss bars. Can't really do the math with them in hand, but it looks like they are at least that 300a rating if they are 1/8.
Matt
I would not add 6s yinglong to 5s titan8/scibs. Personally I wouldn't do 5s lto at all yinglong or titan8/scibs. Since 5s maxes at 14v and...
926
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
Got everything installed and running. It's definitely dragging my idle down a bit, I may bump my idle speed up a few hundred Rpm until the voltage...
mat3833
mat3833
florida
mat3833
    Apr 26, 2024
    Apr 26, 2024
