Switching From 8's to 10's
I would try 4 more 8’s and a second 3500 watt amp. Double the power and double the cone area. If the box is anywhere near big enough it will be louder.
This is what I'm thinking. New box. Only ½" taller. A bigger wedge for four HD10's.
How about this? Top port instead of side port for more port area and greater internal space to mount the subs?
I need the port to load against the passenger side. The port is about 4" from the side. I think 4 - HD10's is the way to go. 1,200 ounces of motor and 3" voice coils.
If I do 4 - 10's then the box will have a slightly larger wedge port on the passenger's side. This is what I have now.
I was thinking like this... the red area would be the port which would give you all the green area inside the enclosure... I think it would give you more airspace per sub.
Do you think that’s enough airspace for those 10’s? Website recommends 1.5-1.75 per sub but as discussed, not sure how accurate their specs are.
Deff not going to hear much of a difference of the 4 ch amplifiers unless you are going to 100 rms per ch. With 10 watts, its just not worth the...
704
Hello! i have too problems with head units, two cars, old mazda 323f ba and now mazda 6 2007r station. Problem is from lossing quality, poor bass...
Yea, I'm running 6S2P. 12 cells total, 2 banks of 6. Resting voltage isn't as big of a concern, it's more about charging voltage. LTO shouldn't be...
Hi everyone... reaching out because I'm a beginner in car audio and need some help understanding how to correctly mount my new radio. I have a...
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
djdilliodon!
    May 20, 2024
    May 20, 2024
