Speaker and amp combination advice please
RussellJ
Hello! I am new to the world of car audio! And I just want to ask if the following setup is wise/works at all without damaging anything! Be kind, as I may have jumped the gun with excitement and bought the wrong peripherals. But wanted to see if you guys think this will be fine to set up or a big no-no.
HU: Already exists in the car (Toyota GT86/FRS/BRZ) Sony XAV-AX1000
https://www.crutchfield.com/p_158XAV1000/Sony-XAV-AX1000.html
___________
Amp 1: Pioneer 1000w GM-A6704 - 4-channel 60 watts RMS x 4
https://www.crutchfield.com/p_130GMA6704/Pioneer-GM-A6704.html
Speakers Front (Doors): Memphis Audio PRX602 Power Reference Series 6-1/2" 2-way car speakers 50 watts RMS (100 watts peak power)
https://www.crutchfield.com/p_953PRX602/Memphis-Audio-PRX602.html
Speakers Rear: Memphis Audio PRX4 Power Reference Series 4" 2-way car speakers 20 watts RMS (40 watts peak power)
https://www.crutchfield.com/p_953PRX4/Memphis-Audio-PRX4.html
____________
Amp 2 (Sub): Pioneer GM-A3702 2-channel car amplifier - 60 watts RMS x 2 at 4 ohms (95 watts RMS x 2 at 2 ohms)
190 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode)
https://www.crutchfield.com/p_130GMA3702/Pioneer-GM-A3702.html
Subwoofer: Kicker 48TCWRT672 - 2 ohm 150 watts RMS (300 watts peak power)
https://www.crutchfield.com/p_20648TT672/Kicker-48TCWRT672.html
____________
I've highlighted the power ratings. My worry is that the amps are too powerful for the speakers. I've done some maths (I think) and I could be overpowering my speakers.
Advice would be much appreciated.
Thanks and I hope you're all doing well!
J.
Thanks, Bobbytwonames. Will try that when I get to the build. Would I still be able to balance correctly from the HU when it's powering a pair and the others are connected through RCA?
If I went down the original route; amp power would be fine on these speakers?
Thanks,
J
Thanks,
J
If you go the other route then just buy a mono (one channel) amp for the sub.
Not too much power.
You could buy very powerful amps and turn the gain down as well. It's way safer to have too much power than not enough. We are all big fans of 'headroom'.
RussellJ
RussellJ
Dubai
KicktheSDbasshead
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
