Wiring advice please. :)
  • 2
Ailas1951
WA
Hi there,
I am doing an audio upgrade in my car and I am currently researching how to wire it up before I do something wrong.
I'll try to explain it as simply as possible.
Head unit has 3 outs, Front, Rear and Sub.
I want to run 2 amps, 2 subs, and 4 speakers. (1 Amp = 2 Speakers 1 Sub)
Most of it seems pretty straight forward, but->
What configuration of RCA leads would I have to run to make this work?
Can you get away with 1 RCA lead on channel A for speakers and a sub or does it need channel B input?
Im feeling like Front preout will go to channel A on Amp1, Rear preout to channel A on amp2, and sub output will be split to channel B on both amps?
Headunit: Kenwood DDX920wdabs
Amps: Pioneer GM-D9704
Subs: Pioneer TS-A3000LS4
Speakers: Pioneer TS-A1680F
Thank you
309
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
433
307
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
558
Ailas1951
Ailas1951
WA
Grimmjoww
    May 11, 2024
RedRyder18
    May 11, 2024
