JP23 or ?
The SQ stuff gets crazy crazy expensive and I’ve been to a few events around here which is fun but SQ is more subjective as well.
Yeah I agree on the 30 second vs burp.
So back on this thread, what would you recommend for Thx?
With his budget a Taramps Smart3 or Cab22. I've yet to hear a Cab22 so that is just based on reviews. I think he should get a SIA2500. The SIA is a smaller SALT board. It has a lot of Korean parts. I think they are the best full bridge amps out there.
Serious question... Why is one better than the other. The SIA2500 has so much less inside and the CAB22 looks so traditional. They obviously make power in different ways.
I'm sure that the Cab22 is probably a good amp I've just never heard one or seen anybody else running them. I see a lot of people running the SIA3500. It might just come down to personal preference and the amount of space that you have. I have two amps in my truck under my seats. SIA3500 for the bass and a Crescendo S4 for the mids/highs.
And the JP23 v1.5:
  • Rated Power Output 2300
  • RMS power, 1ohm : 2000w @ 12v | 2300 @ 14.4v
  • RMS power, 2ohms: 1000w @ 12v | 1300 @ 14.4v
  • RMS power, 4ohms :700w @ 12v
  • RMS power, 2ohm Linked: 4900W x 1 14.4v
  • Frequency Response: 10 Hz - 250 Hz
  • Low Pass Filter: 35 Hz - 250 Hz
  • Subsonic Filter: 10 Hz - 50 Hz
  • Bass Boost: 0 - 9 Db
  • Input sensitivity: 6V - 0.2V
  • signal to Noise Ratio: 88dB <
  • T.H.D @ 4ohm: less than 0.1%
  • Single unit fuse rating: 200A
  • Strapped fuse rating 400A
  • Length (inches) Width x height (inches): 17.71x 7.32 x 2.19
  • Damping Factor: 100
CLASS: D - DIGITAL
And the JP23 v1.5:
CLASS: D - DIGITAL
This is what I don't like.
Not using the bass knob but amp to the touch,barely warm after 30 minute ride Edit: not going full tilt for that long either.way too loud for that...
  • Locked
Well then you might as well just buy it brand new, even though mine has only a few days use on it. I'll do $300 + plus shipping. East to west cost...
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
ThxOne
    May 8, 2024
    May 8, 2024
