I have a 0g wire with a 200a fuse. My question is is it safe and or okay to run it with a 450w draw from my amp. I guess I’m buying cheap and putting off buying the 8g wire kit with a 35-50 amp fuse
You fuse for the wire, not the amp. If the amp requires an external fuse, you run your 0ga to a distribution block, then run smaller gauge to the amp with the proper fuse in-line on the smaller wire.I have a 0g wire with a 200a fuse. My question is is it safe and or okay to run it with a 450w draw from my amp. I guess I’m buying cheap and putting off buying the 8g wire kit with a 35-50 amp fuse
