Accessories interfering with my Subwoofer.?
Noise can be introduced through RCA cables. Be sure to use high quality shielded cables and try to keep them away from any big power cables or possible sources of noise.
Also if your head unit is low quality or has an internal fault (such as the infamous pico-fuse issue in some Pioneers) that could be a point where noise is being introduced.
You could start by getting 20 feet of quality RCA run it to the amp just loose and see if the noise issues change right away or as you move the RCA closer or further away from different points in the vehicle. https://www.nadbl.org/index.php/event-calendar
You may need to look into getting at least a 30-40 amp relay installed also for the Lights and one for the CB may help. As stated.. make sure your ground connection is solid and secure for your amplifier
GoT_2B_BuMpN
GoT_2B_BuMpN
No Conway, New Hampshire
GoT_2B_BuMpN
