LoneWolfie
Hi, i have a pioneer Premier 12" on a Rockford Fosgate Prime 500w. Ive had voltage drop issues for about 1-2 months, 2nd battery warranty, and a 145amp alt with 4g charge cable. Ive noticed recently that the amp will go into protect when under load on acceleration. After checking the amp, fuses and wiring, I grabbed my spare Premier 12" (have 2, only using one) and it won't go into protect under same conditions, nor is the voltage drop near as bad. Anyone know whats wrong? Exact same subwoofers. Amp will also jump in and out of protect when it does go into protect.
Wiring is 0g power/ground, 12g speaker wire if it matters. Sub is wired to 2ohm
