Tweeters
You need to find out what ohm load they are showing. So us a DMM and measure the ohm load. Find an amplifier that will accept the ohm load. Example: It measures 4ohm I would look for a 2 channel amplifier and run it in a mono configuration. Left positive right negative on most 2 channel amplifiers.
It says 8 ohms and 300 watts
Ok and just hook it up to one channel or both And use distribution block for power and ground
Just buy the amp and have it professionally installed. Nobody knows what your system consists of and you sound very inexperienced. Just get it installed by a pro so that you don't blow anything up.
I can do it if I can just figure out the amp. And wire hook up
One of your amps should have RCA outputs. Use those to feed the tweeter amp. Power and remote wires from the distribution blocks you mentioned. That amp is 8-16 Ohms capable so it will not do. Find a 4 Ohms bridgable amp. That way when you bridge, it will play into a single 8 Ohms load. Make sure it has a built in x-over.
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
114
8K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
fjack
fjack
New York
HondaCRV03
SlugButter
    May 4, 2024
slater
    May 2, 2024
