doin it right?
  • 5
Where's the battery, and where are the amps located?
If it's a typical under the hood battery and the amps are in the trunk, no.
If it's something like an equinox where the battery is under the rear floorboard, and the amps are going under the rear seat, yes. Similar example would be a BMW or Mopar sedan with the battery in the trunk, and amps going in the trunk. In those cases, it makes perfect sense to run an amp ground to the battery.
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
891
Hello, I already posted in general but wanted to also post in here. I recently installed a set of used JL audio shallow depth 12W 1v3-4 inside an...
Makes sense. You may be right on the gain; 2 subs on 300 watts seems anemic.
46
4K
TwistedSkipper
TwistedSkipper
sacramento
Slo_Ride
pfft
    May 1, 2024
pfft
    May 1, 2024
