needing help with wiring of head unit
curren
A bit new to this but i am looking for a little bit of help, i cant seem to find any ground,power,illumination,constant 12v wires any help would be appreciated, 2005 mitsubshi lancer wagon model...
32811
Where is the rest of the harness i.e the plug it has on the end of it that plugs into the OEM radio. You are best to just buy the wiring harness that it needs and the wires will match up very easy then vs cutting off the OEM harness and trying to figure things out. Those harnesses are not all that expensive 5-15 bucks and worth every penny.
when i got the car it didnt have a harness or a head unit in the car and it seemed like most wires were missing or cut somewhere that i cant see besides the ones in the picture, tried finding a wiring diagram for it but none of them match, im sure its a 14 pin but there are only 8 wires even after searching for a bit.
Yeah someone did a hack and cut job instead of spending the few bucks and doing it right then.
See if you can take the part numbers here from Scoshe and get them in your country or something like it. As what you need is a factory replacement harness then a harness that plugs into that from your aftermarket radio.
This search on eBay should help as well with some part numbers. Then as I said you reconnect the oem style harness to the wires as they should match up then. Then buy said other harness that plugs into it so you can just match up the wire colors to the harness coming out of the aftermarket radio.
ill check it out thanks for the help 👍. will the rest of the missing wires be a issue at all...? since being a 14 pin originally and only having 8 wires in the car now.
thank you bro ill
thanks bro 😄 could u help with finding a wire diagram at all 😅
Use this as a testing guide:
It seems you are missing the harness for the rear speakers. It should be in there somewhere, or those other blue wires poking out the bottom might be their replacements. Use a multimeter to determine if this pinout is correct.
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
You got plenty of space 30"h x 40.5"w x 65"d even triple baffled, double walled with bracing. What vehicle is this going in may I ask?
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
853
272
234
curren
curren
new zealand
    May 23, 2024
SPLBassJunkie
    May 21, 2024
