Yes it's that guy.If this is the amp your talking about then it's defiantly the one you want to go with
If for some reason you don't use it I will gladly buy it from you
But also... Let me in on the secret? What's it put out at 1 ohm stereo?If for some reason you don't use it I will gladly buy it from you
Yea I can only find the manual for the ZX online. And they publish the ratings very interestingly.. it'll do 300x2 at 2ohm. Then a couple lines down it says minimum load stereo.... 1ohm.I can't find anything on the 600 but the 1200 did almost double its rated power at 1 ohm stereo (1150 a side)
The 1200 is essentially 2 600's put together so it would be fair to say you could get 550- 600 a side out of it (1100-1200 total)
They are not as durable as the old M series that you could run down to .5 ohm though so I don't really suggest running it at 1 ohm for extended periods of time
Bahaha! And his VW van was probably constantly rattling apart.Standard PG bass knob
I think the numbers would be more like 800 @2 and 1000+ @ 1
Depends on what kind of shape the amps in
I will give you an example
When they first came out I guy I knew had one running 4 Dr Crankenstien 12's in a VW van
He lived not far from me
I could hear him coming up the hill when he came home a night
5-6 blocks away easy
I hated that guy
Haha! It was user error... I got it to play but it's got something crazy going on. If I mess with the gain it'll like cut in for a second then cut out. And there's some very odd noise I never heard from a sub before. Kinda sounds like a baby possum is trapped in the box and tryna get out
