Subwoofer making weird noise on short notes
joshgelz
So when i first got the subs I noticed this, Overlooked it as something minor as it wasn't that bad untill a couple days ago i realized it suddenly started doing it very frequently. The noise is hard to describe, it almost sounds similair to a dog bark, it only happens on the short kicks, and in songs that utilize that alot it gets very annoying. I have no idea what could be wrong with it, because in songs like Many men (21 savage) or Put on (jeezy) where the bass is more constant, there is no issues at all.
Go along the perimeter pulling on the edges of the dust cap. I've had this happen a few times, and just as described, it was noticable on kickdrum and sharp bass notes. I use black speaker suspension glue, it works great and easy to pick at the excess once cured.
So essentially remove the dust cap then glue it back on?
That would be the best option. Sometimes the rest of the dustcap is glued well, and pulling it may damage the cone. In that case it is best to just glue the loose portion. I would put a paper over the loose edge and stencil the dustcap. Then trace and cut out masking tape to protect the cone from excess glue.
This is only after ascertaining that there is in fact, a loose dustcap.
on my enclosure there's a plastic ring screwed into the edges, should i remove that to check, definitely a newbie, sorry for the questions haha
Glad to help where I can. The dust cap is the dome in the center of a subwoofer. Some are a dome while others are concave. Some are the size of the entire cone. Unless it has a grille, there is no need to remove the outer trim. Would you post a picture of the sub?
30961
9/10 you are bottoming out.
Usually from being overpowered and on a note that the box cannot control. My 6.5s I have to be careful with since I'm throwing 2k to a pair of 200w subs
I only have a 1200 watt amp on 2400w subs though, and when I listened to videos of subs bottoming out it didnt really sound similair, i could be wrong though.
What subs and what amp?
And what box specs because bad box tuning can exaggerate the effect. Especially if the box is oversized or tuned to high
And there is multiple forms of bottoming out.
It is true that the dust cap might have come unglued but thats unlikely.
it was the "DUAL 12" 2,400 WATT SDR SERIES COMPLETE SUBWOOFER PACKAGE WITH VENTED ENCLOSURE AND AMPLIFIER" package from skar, With 2 12' SDR-2X12D4 subwoofers, the Skar Audio RP-1200.1D Monoblock amp and the Skar wiring kit.
Post up a video, if you can.
You are looking at max power ratings on those subs. They are only 600 watt rms subs. Never look at max power ratings on subs, speakers or amps. It sounds like you are bottoming out. Turn the gain down a hair and see if it still does it.
I have also had subs do this. On quick, loud bass notes the Voice coil would bottom out and sound like a fart/bark. Too much instant power and not enough suspension travel to keep the hard VC former from hitting the backplate.
Solution = Set the gain so that there is no over-excursion.
My subs will actually only bottom out if my passenger door is open. For some reason just opening the passenger door during a demo will cause them to unload and bottom out. Are you driving when it happens? Try playing your system parked with both doors closed and see if it happens.
joshgelz
joshgelz
Pennsylvania
Buck
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
