How to set hpf and lpf on sa sfb 1000?
MyNameIsHere
117
USA
I can't figure out how to set the crossover on the amp.
30574
Right now they are all the way to the left. I just have to set gain.
The hpf isnt supposed to be all the way to the right?
No the HPF works as a subsonic filter. I forgot you don't have an aftermarket headunit so you will want to set the HPF depending on your box tuning.
say you are tuned to 45 Hz:
- 45 Hz / 2 = 22.5 Hz (one octave lower)
- 22.5 Hz /2 = 11.25 Hz (half an octave lower)
So we take 45 - 11.25 = 33.75 Hz (rounded up to 34 Hz)
In other words, you set your sub-sonic to 34 hz. So that way, if there's music below the ports frequency, it gets filtered out protecting your woofer.
Always remember the subsonic filter is NOT a cut-off. It has a roll off "slope" where whatever frequency its set to will be attenuated, and the attenuation effect increases as the frequencies get lower. Thus the power to the woofer decreases at filtered frequencies, which reduces the excursion and risk of damage.
My subs are sealed
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
468
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
599
Send me all the items. Once I receive them, I will verify everything in your classifieds. If someone buys them, I will ship out. You would just...
852
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
MyNameIsHere
MyNameIsHere
USA
MyNameIsHere
pfft
    May 1, 2024
pfft
    May 1, 2024
