Need a DSP
djbeats
I am slowly putting a system together with more emphasis on sound quality for my 2019 ram 1500. The plan is to put a 3-way 4-ohm component set up front, new 6x9 or 6.5 rear door speakers and a 10 inch ssa demon sub under the back seat all with the stock head unit. I have a crescendo amp for the sub and would like to power the remaining speakers with one amplifier. Currently I am concerned with getting the sub in and would like to use a DSP to get the signal from the stock head unit to the sub and speakers (future). How many RCA outputs do I need? Also, any recommendations on a DSP?
Rockford Fosgate DSR1. Maestro should have a plug and play harness for your truck.
So your front 3 way components are going to have passive crossovers? You aren't going to run them active?
If you are running passive components up front, the rears, and subwoofer 6 channels is enough.
The front will definitely be active. Right now I am looking at a helix or a zapco dsp. I will probably have enough outputs to run the rear active as well.
Go to DIYMA some people there are willing to remote tune it for you for a small fee. Usually around 30-50 dollars.
There is a Michigan MECA Facebook group that is pretty active. They should be able to point you in the right direction.
173
204
djbeats
djbeats
United States
tylormcvey
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
