ThatOneGuy1175
I'm running 2 skar VXF 15s and they're conservatively rated at 1500 rms each. Should I go with the rp3500 or the taramps 8k? Trying to get the most out of them and not kill my pocket.
Taramps 8K if it were me. Cant go wrong really. Of course, that’s if you already have a solid electrical. If not, probably the 3500 as getting the 8K would mean you’d need to invest in more electricalI'm running 2 skar VXF 15s and they're conservatively rated at 1500 rms each. Should I go with the rp3500 or the taramps 8k? Trying to get the most out of them and not kill my pocket.
Im getting a 320 amp brandTaramps 8K if it were me. Cant go wrong really. Of course, that’s if you already have a solid electrical. If not, probably the 3500 as getting the 8K would mean you’d need to invest in more electrical
I'm getting a 320 amp brand x alternator Friday and either a xs d3400 or a limitless 15ah. You think I'll have enough electrical to run the 8k?Taramps 8K if it were me. Cant go wrong really. Of course, that’s if you already have a solid electrical. If not, probably the 3500 as getting the 8K would mean you’d need to invest in more electrical
So with my 320 amp alt and a 15ah lithium whats the max wattage i can run? Also how do I wire a lithium battery if I have a stock battery up front?Those 2 amps are not even close to being in the same category
Not to mention the $1000 in electrical upgrades your going to need to run the Taramps
Look at one of the lower Taramps or the SFB line from Sundown something around 3500 watts like Cynic0l said.
I think @Popwarhomie can answer that a lot more accurately but me personally, if you went as far to get an 320A HO ALT, I’d just get the Lithium(but LTO not LiFePo4 like limitless), and I think you’d be okay. I myself am running 2 Taramps 3Ks, a 1200x4, & Sundown SFB 8K on a 28ah LTO and 320A Singer Alt for now.Im getting a 320 amp brand
Preferably a battery delete in the front unless you can run 2 Alternators, 1 for your car & 1 for your system. I’m doing a battery delete but if I wasn’t so impatient I’d run 2 Alts.So with my 320 amp alt and a 15ah lithium whats the max wattage i can run? Also how do I wire a lithium battery if I have a stock battery up front?
The limitless is good up to 3000 wattsIm getting a 320 amp brand
That doesn't really take into account the 320 amp alt
I'm sure you can get away with more but I don't know about 8000, maybe?
Why are you so determined to get the 8000
That's putting a lot strain on your electrical that you don't need
If it were me I would get the 3000 or the 3500 and put the money I saved into getting better subs
[/QUOTE
Im stuck between the 8k and 3500 because I can upgrade to more or higher powered subs without buying a new amp. And what brand LTO lithium do I need to look for and what's wrong with lifepo4?
Shoot I have my installer doing that lol but pretty much you’re just replacing the stock with lithium. Your lithium is running you car and system.how do I wire the lithium if I have a stock battery up front?
If you have to ask, the answer is "NO".You think I'll have enough electrical to run the 8k?
Really? What's the discharge graph look like at 20C? How about the cycle life? What C rate are they rated at and what is the max/burst rating?The limitless is good up to 3000 watts
