Amp not turning on
  • 5
I have a switch on the remote wire to turn the amp on/off when I try press this, the amp lights up and quickly goes out. Would this still indicate the amp is bad ?
Okay I’m gonna bring it inside and try it with power supply and if it doesn’t still turn on I will have to buy a new one.
the current amp is a kenwood kac-5206 and run a kenwood KFC-W112s
which amp would you recommend to get to pair with the sub? Something within budget
That link just takes me to eBay? No product
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
838
You tried the external relay with no success? If so, how did you wire it?
18
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
185
  • Locked
433
G1killer
G1killer
Yorkshire
SPLBassJunkie
    May 21, 2024
    May 20, 2024
