Need advice on installation quote given to me
Voland902
Hi. I'm just looking for advice on a quote I got at a shop for an installation on my car.
Car is 2011 Hyundai Sonata SE with Navigation and already has an amplified system.
My parts are
2 10" JLW3
JL RD 1000/1
JL Slash 300/4
6.5 JL C2650 Components for front
6.5 JL C2650 Coaxials for Rear
LC7I output convertor
They are quoting me 1500$ for everything
Just wondering if this price is reasonable or I should run for the hills.
For me that’s a lot but I DIY. Usually if you buy equipment from them and get it installed, you can negotiate more. Since they aren’t making any markup on product, labor tends to get more expensive if that makes sense.
It is expensive, but that is a lot of work. I've done many full basic installs like that. Different shops have different quality, service, extra things they do during installs, like how they secure wires and quality of the stuff they have to add during an install. If you have zero desire to do it yourself and you pay that much for them, make sure that they'll help you when you have problems or need maintenance type work done. I would make sure it's a shop that isn't going to one and done you kind of thing. That kind of price should come with high quality install materials and support for future needs.
I will say installing car audio can open up the doorway to understanding how a lot of other things work. There's a lot of basic physics that can be learned while installing and tuning your own audio that will make you understand more about other things.
That seems high, especially if you already have an amp and power wire running to said amp. I assume they are not sound deadening? Are they building the enclosure? Making an amp rack?
Maybe ask if they can do it for $1200.
Also they now have no control of quality or fitness of whatever they install so it is significantly more risky to put in stuff that they do not sell/service.
Seems a bit high, but it is a big job, and most of these shops have to bid jobs at roughly the hourly rate of any sort of automotive garage to stay afloat so compare to the cost of say taking your car in for some major repair or body work when you try to figure what a "fair" hourly rate is in your area.
If they are building the box I'd say that's fair
For arguments sake say $100/hr for labor its probably higher than that but just for an example.
$300-$400 in shop supplies (wood, wires, fuse's, carpet ) again just a guess
Then 11-12 hours in labor
Be thankful you don't want fiberglass work done
That number would have been more like $4000-$5000
Fiberglass costs will make you faint
And it will be worth every penny spent. AWG corrodes faster and the strands disintegrate and have to be cut back and refreshed almost yearly to...
Signal flow should be HU to DSP to amps. You would lose the ability to EQ and time align the sub with the DSP unit if you bypassed the DSP.
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
314
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
Voland902
Voland902
Indiana
focused313
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
