4th order possibly, which pair of 8’s on 1200watts?
  • 7
That sub may actually work in a t-line. The fact that it would work in that large of a ported box means it would be more likely to control itself in a t-line. It has a pretty decent Vas and a low Qms, which helps explain the box size. All that plus the low Fs makes it look like a large box low end woofer more for home audio use, IMO. Made to reproduce low rumbles. I mean they recommend you tune it to 20 hz lol. That's almost certainly home audio oriented.
Not a 4th but a t-line like you suggested
These! Fs is 41.6 and rms is 500.
So, one 12” (the Dayton UM) or a pair of 8’s( the sa’s Bobby linked), which I actually had looked at earlier? I’m down with either of the 2 brands. Wonder which would require a smaller box? Or even which would model best for a t-line.
The fs on those sundowns is a little higher then ideal for a t line but I had an SA 12 in a t line that sounded amazing so all depends on design
Still have the box! If you find yourself in st.louis I'll sell it cheap!
Why dimensions is the box? Just want an idea of what size enclosure Im looking at.
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
924
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
Ridinhi
Ridinhi
Winston-Salem, NC
Ridinhi
    May 8, 2024
    May 8, 2024
