Newbie Question
  • 6
kevincali
So I have gone through now 4 sets of 6x9 speakers which means I must be doing something wrong and should have asked for help a LONG time ago. What I have is a Kenwood Marine deck on my Harley and 2 400 watt amps, I bridged the amp for the front 6.5" speakers and did the same in the back with another 400 watt amp. However I continuously blow either one or both of the 6x9's in the back. My question is I know with the amp being bridged I am pushing 200watts to each speaker do I need to make sure the speakers can handle 200Watt RMS? I'm not sure what RMS means or stands for but it is a term I have been seeing over and over again while I look for replacement speakers.
That amp does 90 watts rms x 2 bridged. I think you have the gain set too high and clipped your speakers to death.
Look into a speaker with a higher sensitivity and lower power handling.
I second the Polk speaker suggestion, check into the Polk MM 692. Marine rated 94 db sensitivity. They are rated to take way more power than your amp can send them, but from what I've heard they can get pretty loud even on lower power. Also make sure your gains aren't set to high as was mentioned before.
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
I think it is the input sensetivity. Indicating you can wire direct ftom speakers.
21
You could control the radio from your phone but that's about it. I do not think you can, but if you could, for on screen phone it would have to...
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
756
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
kevincali
kevincali
California
LsGuy
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
