2 dvc 2ohm to .5 ohm 1 channel....please help
  • 2
Pineapple 🍍
Hello all, I'm not sure if I'm overthinking this or what, however I rather be safe than sorry. I currently have 2 massive audio hippoxl122r 2 ohm dvc subs(3,000w rms, 6,000 peak ea) and am currently in search of the best amp to achieve maximum potential without blowing subs or putting amp into protect mode. The electrical system is a 270a Brand X alternator(2014 kia soul ! 2.0L engine), cyber12k Lithium limitless battery, 0 guage welding cable. At the moment, I'm considering the Taramps Md12000.1 .5 ohm single channel amp. I hope to run them at either a .5 ohm or 2 ohm. I'm concerned however that this may be too much power, but then I consider box rise. Please give advice. Thanks in advance.
Before I started to cut wiring, I would just leave one of the connectors unplugged. Based on your 3rd image, it looks like the wiring was spliced...
Its never justifiable to rush a clean install. Its best to do research for the proper speakers needed and wanted and amplifier to supply for the...
37
6K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Pineapple 🍍
Pineapple 🍍
San Marcos
Pineapple 🍍
DEW123
    May 7, 2024
DEW123
    May 7, 2024
