Good, Reliable, Cheap(ish) Amp Brands?
1,200 watts at 1 ohm.
I’ve been told I should up the amp for peak performance of my sub. I’m looking for 1200-1500 watts, 1-ohm stable mono. So what brands should I look into? Trying to keep it $300 max.
I would go with boss audio sound systems there great I have 2 subwoofers and 2100watt and 4 ohms with a boss 1200.2 amp and they knock so well im I play my music at max volum
You should look up boss audio amp dynos aka where they measure the true rms the amp puts out. You can make better choices later on with amps that actually do real power
US Acoustics Mike. 2 year warranty as well.
Your the 3rd person to suggest this amp so hopefully you can help me understand something since I don’t know amps that well. If the Alpine X is dual 4 ohm, and to my knowledge can only be wired down to 2 ohms; how would this amp be good for my sub when it’s rated to push 750 watts @ 2 ohms.
That Sony XM-GS amp should be a good choice for you. I’ve read a lot of good things about it. And, for the price, looks like you can’t beat it.
21
4K
My first install on my vehicle was in '94 right before I turned 18 😂 I'd "helped" on a few starting at 16 but my helping was mainly gofer work...
19
I have not really heard anything bad about Vibe Audio. If you are buying it new, then no reason to not try it out. It may have a 3 month...
Marve_Lous
That Guy
Marve_Lous
Houston, TX
Clifff150
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
