- Thread Starter
- #16
Thank you, just tried this. Plugged phone straight into the amp and the noise went away. Amp is ruled out as a problem. Will have to test RCA's when I pull the head unit back out this weekend. Kind of a pain on this car. I also noticed when I start the car, no sound from head unit, if I crank the volume up there's is a slight staticy sound. Head unit and amp grounded to the same spot, so since we ruled the amp out what do you think the issue is?Get an rca to aux splitter to your treble static afflicted driver's amp plugged directly from your phone. If the problem persists its a system noise issue. If it doesn't, its an rca issue either cable itself or head unit rca outputs
